Private browsing keeps asking for a location despite it being blocked in settings
Description of the issue: Similarly to a previously open issue with no response for Brave on Android, the desktop Brave in a Private window also doesn’t respect set-up site permissions (or at least the location permission). For example, Location being blocked, using the “Don’t allow sites to see your location”, doesn’t seem to apply to Private windows. Navigating to a website which asks for a location will continue asking for a permission as if it were allowed in the first place.
  1. Set brave://settings/content/location to “Don’t allow sites to see your location”
  2. Open a Private window
  3. Navigate to any website asking for a location, e.g. https://mylocationnow.io/, the website will show a location permission prompt
Expected result: No location access prompt is shown
Brave Version( check About Brave): 1.76.80
What are the options for Remember my decision?
Your screenshot shows until I close this site.
At: brave://settings/content/siteDetails?site=https%3A%2F%2Fmylocationnow.io
What - exactly (be specific) - is the Location setting ?
At brave://settings/content/location please take, and provide here, a screenshot of, for example (my older screenshot for older BB version):
Thank you for responding. Here’s the requested information:
The options for are standard options you get anytime you get the pop-up
I believe it is not related, the pop-up should not show up at all.
At brave://settings/content/siteDetails?site=https%3A%2F%2Fmylocationnow.io it shows the location is blocked and that is expected - in normal browsing, Brave is blocking the location access as expected; it is only the Private browsing which keeps prompting for a location
Lastly, here’s the full screenshot of brave://settings/content/location
Also, if I may, here’s a GIF showing the difference accessing the exemplary site in a normal and a Private window
brave_location
