Preformance Issues
Description of the issue: I recently formatted my pc and i reinstalled brave and everything was fine but i realized brave is so laggy on sites it shouldnt be laggy on. For example on https://nitrotype.com it is so laggy almost unplayable and im not sure why. As well as https://monkeytype.com and the list goes on. How can i fix this? (PS. those sites worked complelty fine before i reset my pc.
How can this issue be reproduced? N/A
Expected result: N/A
Brave Version( check About Brave): Version 1.37.116
Additional Information: I have tried Brave Beta and it didnt fix any problem i also tried disabling Hardware Accerlation same issues.
Disabling hardware acceleration may make it feel more laggy, since it won’t use your GPU.
What does ≡ → Task manager show? Can you also test private window mode?
Hello,
I recently had a similar issue. If you are by chance using an Nvidia card try a reset of its global settings on the Nvidia control panel and make sure background application max frame rate is off. I was able to trace my own performance problems back to that particular setting after the recent update.
My GPU Process goes to 400% CPU and NItroType uses 13% CPU. Private window makes it even worse.
I have an AMD Card. I tried looking for any framerate limits on the AMD app and i didnt find any.
Bumping this post! Still never got a solution.
Bought to hop on duckduckgo beta once its outs or Epiphany browser, this browser is getting so annoying.
@clap Don’t know if these will help or not, just something else you might want to try if you haven’t already and are still experiencing issues.
