almost all branching websites from (i only use it to stream soccer but it has all sports)
(just one specific game i was watching today but this problem has happened on this site the whole time i have used this browser)
its a different ad whenever you try to start the video player
after 3 or so times it wont bring up an ad
sometimes the ads are in a new tab (this link)
other times the ad is in a new window (that starts at min size and changes from min to max over and over in the backround)
**Did the issue present with default Shields settings? (yes/no)**NO
**Does the site function as expected when Shields are turned off?**dont know
**Does the ad appear when using a Private window as well? (yes/no)**YES
What OS are you using when you see the ad? Windows 10
Brave version (check About Brave): 1.77.97
