After updating to latest Brave, pinned tabs when using vertical tabs can no longer be distinguished from regular tabs.
- Set tabs to “Use vertical tabs” (make sure you don’t have “Minimize tabs” activated)
- Open a few tabs
- Pin some tabs and keep some unpinned
Pinned tabs when using vertical should be visible as pinned, just as they are in horizontal mode.
v1.71.114
When switching to horizontal mode they are highlighted as pinned (have a little border). I’m using dark mode.
On this screenshot, all tabs up to the start tab are pinned:
