Pdf viewer built in
I tired help and did not find an answer. also i tried extensions and could get none of them to work?
Is there or would you please add a “built in” pdf viewer? thank you.
This needs to be a thing. Being unable to view PDF’s inside a web page is really difficult to deal with in a work environment.
I switched to Brave a few days ago, it automatically installed the Adobe Acrobat extension. I don’t really feel comfortable with that so I removed it.
I have just viewed some PDFs in my browser, they do work, there is a default PDF viewer.
So why on earth did it install Adobe Acrobat?? Weird!
