Briefly describe your issue:
I didn’t received payout from las 2 months. 7.3 BATs from September and 5 BATs from October month. I was pretty sure that I wont get paid for October month as well. I don’t know what is happening, I raised complaint and also provided all required details to @SaltyBanana , but didn’t worked.
The latest issue is, I reinstalled windows yesterday and today when I tried to login to uphold wallet it says device limi reached. I request you to a least remove every old device attached to my Brave Id. So that I can start earning again.
What Operating System and Brave version are you using (Menu → About Brave)?
Windows: 21H1(Build 19043)
Version 1.31.88 Chromium: 95.0.4638.69 (Official Build) (32-bit)
Yes
06/06/2021
Yes
Are you using a VPN? (yes/no)
No
Are you in a supported region (see here 2 for list of supported regions)?
Yes
Does your device pass the SafteyNet 1 check (Android only)?
Yes
Yes
