On iOS, right-click “search web” for selected text uses Google instead of default engine
When selecting text on a webpage and then using the “right-click” popup menu choice of “search web”, Brave uses Google search even though I have my default search engine set to Brave.
  1. Open a web page on Brave app
  2. Select some text so that the right-click menu appears.
  3. Choose “search web”.
  4. A new tab to Google.com will appear with your search.
Since my default browser is set to Brave Search, I expect it to use Brave, not Google, to do the search.
ios app v1.82(171)
Mobile Device details
Ipad pro M4 running ios 26.0
I am trying to stop using Google. That’s the entire reason I am using Brave. I don’t want this to use Google search for anything.
Hi @CynthiaS this is a known limitation of iOS, we’ve tracked the issue here: https://github.com/brave/brave-browser/issues/47286
OK, thanks for letting me know. This is a very bizarre thing iOS is doing. I hope you can fix it soonish.
Also - aren’t I supposed to report issues to this Community Forum? Am I supposed to be searching through issues in GitHub in addition to here before posting? Yikes, I hope not.
cheers, c-
@CynthiaS You can report issues in either location, but searching for if your issue exists in either place may be tricky depending on how other users may have reported it in the past so no worries!
Great, thanks for letting me know!
cheers,
c-
@CynthiaS Just to update, I opened a new issue for this: https://github.com/brave/brave-browser/issues/49623 and opened a fix for this as well which replaces “Search Web” with “Search with Brave”. As a workaround until this feature ships, you can continue scrolling to the end of the same context menu list where “Search with Brave” should be there
Thanks!
And, I had not noticed “search with Brave” was at the end of the list. GTK.
