Number of Ads displayed is not meeting 10 per hour, drastic reduction in number being displayed.
Please dont just reply with a stock reply saying, “have you read these guidelines?”.
I am no longer receiving the rewards you state you will pay to me.
Number of ads never meets 10 per hour. Actually there used to be a limitation of 4 per hour. That 10 is the absolute maximum that can ever be reached.
The number of ads depends on the campaigns available in your region and on the way you use your browser.
Currently, due to the bear market, global economic crisis, war conflicts, etc, all companies are trying to save costs. There are less and less advertising campaigns.
Actually, most ads nowadays come from brave itself, not so much from Brave customers.
Hints on how to view more ads:
The Crypto market is / was in a bear market and is just strating to recover. Therefore not many advertisers want to advertise right now, hence the reduced number of ads. You can check active campaigns at
https://sampson.codes/brave/ads/my_region/
Also, the limit just says that you may get 10 Ads / hour, it in no way suggests that you will get 10 ads for sure.
