now brave a lot of problems almost every month the most prominent in the choice of claim I’m sure almost every user has experienced this, why the claim does not appear? @steeven
You may wish to repost your issue to the correct forum section here:
In addition, you would want to provide the details in the following template below, so that Brave Support or the community can see the technical details of your issue, and how your issue happened.
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
Briefly describe your issue:
Are you using a VPN? (yes/no)
