My desktop brave browser prevents me from visiting https sites by telling they are not secured.
See attaced picture
Brave Version( check About Brave): [
Version 1.30.87 Chromium: 94.0.4606.71
It’s probably because of this: https://techcrunch.com/2021/09/21/lets-encrypt-root-expiry/
What version of iOS?
There are some workarounds posted in this thread: NET::ERR_CERT_DATE_INVALID Error on All Sites
But I’m not sure if iOS is covered there. But in short, this is a likely a consequence of running a severely outdated operating system. If you’re running a newer, supported version of iOS then maybe it’s a different issue.
Thank your for your replay and effort <3
The iOS is 10.11.6
OK. Looks like it is almost definitely that issue. https://letsencrypt.org/docs/certificate-compatibility/
Not sure how to deal with this on iOS, maybe someone can chime in; otherwise I can try some searching later and see what I can find.
