Not able to add extensions
I am not able to add to new extensions in my Brave browser, everything was working good before some updates but now its showing error.
Tried installing Metamask and React Developer Tools
Operating System : macOS
![Screenshot 2022-07-06 at 15.29.51|690x343]
(upload://bJ0VVpbeRi0M1yQd2t0a1yfjb6x.jpeg)
@knight95
You might ‘have to’ Disable and Remove some, or all, Extensions . . . and then install React Developer Tools.
Also - for passersby:
https://chrome.google.com/webstore/detail/react-developer-tools/fmkadmapgofadopljbjfkapdkoienihi?hl=en
Hi
Is it a bug? Many things were tried in the following post with no solution.
Hi,
Just did this on the TEST profile and got exactly the same thing that I get on my primary profile. This is the full URL for the extension in the Chrome store: https://chrome.google.com/webstore/detail/bitdefender-password-mana/ibkoenhablealnikeefmjineccmgegmh/related
