hi folks
i trying documents or even in another site to voice typing like https://speechnotes.co/es/ And I can’t do any voice dictation in brave, I have the microphone activated on the page and everything enabled, I even deactivate the brave shields but I press on the microphone it turns red but it says that nothing is heard …
Is there a solution (I used it a lot on a daily basis in my work)
In chrome if it works perfect
Versión 1.28.106 Chromium: 92.0.4515.159 (Build oficial) (64 bits)
win10 pro
version 21H1
@royroyers,
On the site, can you try with everything normal (Shields = up, mic permissions allowed, etc) but also enable Autoplay for the site and test to see if this works?
If you’re unsure of how to do this:
- Visit https://speechnotes.co/es/
- Click on the
Lock icon in the address bar, then Site settings
- Scroll down until you see the
Autoplay permission
- Set this permission to
Allow
- Refresh the page and test to see if the issue persists
@royroyers,
Actually scratch that above post – doing some digging on this, thank you for your patience.
ok thanks for the answer.
i did everithing but the autoplay it was alloas as default, the mic its allowed too, shield’s up and still the same no change at all _
dont know what else
@royroyers,
Yeah it looks like I can reproduce the issue as well. I’ve reached out to the team for more information here and hope to have a reply soon. If we cannot find a solution I will log the issue on our Github for the developers to review and fix.
