I thought I’d seen claims in the search results I looked at here that there was now an alphabetical sort for bookmarks.
If so, where is it?
The only ‘rearrange’ option I see currently is manual drag-&-drop.
Thanks.
– Brave Release / Mac OS Mojave –
If so, where is it?
Thanks.
Hello @mk7z
go to
brave://bookmarks/
then click on the 3 vertical dots then sort by name
@justsomeone1 There it is, hiding in its little corner. Thanks!
No way to alpha-sort the folders (and their sub-folders) in the left sidebar, though, right?
you welcome @mk7z
you need to get inside each folder and sort it by the same way
Got it, thanks again.
you welcome
