No ads is displayed on my Android phone
Hey there i am also from india and we all getting the same issue i have 152 referal. They all are asking me and i am tired to explain them what’s going on
I talked with a mod yesterday and he said there’s currently no campaign running on andriod for India. However ads on windows are still coming.
Search andriod on this page :- https://ads-serve.brave.com/v2/catalog
If u don’t find andriod then ads for andriod aren’t currently available in ur region (India)
yes this catalog is showing that we are able to see ads may be the reason is differ
Well is there any official statement that in India ads are not supported in Android version
In catalog search for android if it’s not present then it means there are no active campaigns for your particular region on android device
Hope you get the gist
Ads are supported in android version
Whenever ad campaign will start you will start receiving ads
till then enjoy other features of Brave
[ I m from india sir and i m also facing this issue and this is my brave version
Brave - 1.10.99 Chromium: 83.0.4103.116 (Official Build) (32-bit)
Revision 8f0c18b4dca9b6699eb629be0f51810c24fb6428-refs/branch-heads/4103@{#716}
OS Android 8.1.0; Slide_skye_03 Build/OPM2.171019.012
Well this answers a lot I suppose. I dug a little bit and it turns out that we recently made some updates to the ad catalog(s) in India that need time to propagate. There may have been a temporary hiccup in delivery over the past several days, especially on Android. However, we expect ads in India to return within 24h.
Sorry for the inconvenience and we appreciate everyone’s patience and understanding.
Same problem android phone from Philippines
thanks sir the problem has been solved today
Finally. :pray::v:it’s coming back.
Thank you so much ads problem has been resolved!
