No ads is displayed on my Android phone
No ads from past 2 days infact both iPhone android not receiving any ads in India
Please fix this problem asap
Sameeeee :disappointed: I wish they fix it
bro have you tried to run this? Maybe it will help https://www.bennish.net/web-notifications.html
hi have you tried anything to resolve your ads?
Try this if it helps… I do restarting my mobile too
disable brave rewards
disable ads notifications
disable self-contributions
close the browser
reopen it and re-enable all the previous options (brave rewards, ads notifications and contributions)
I received two ads in 1 hour and I see the reward in pending.
In my case it worked, I hope you too!
Same I not received ads from 7 July Could you tell me which is the problems ?
Thanks
i tried everything we know how to fix common bugs
@Arkearn then what we all can do is to wait for the brave team to respond on this issue and fix it.:smiley: sir @Mattches please your help is needed in here.
Eagerly waiting for the brave officials to come up.with something please
Same problem with me also not getting ads since payment updated in my account
yes same problem … im not getting ads in andriod
Same here. No adds since I guess last uphold transcation(6th July) or payout generating day(8th July). India
For anyone here encountering this issue:
Simply telling us that you cannot see ads is not a good way to get efficient support. We need more details about your issue/situation in order to properly diagnose it. If you are still not seeing ads, please tell me:
  1. Whether you’re using Android/iOS and what device type/model it is
  2. What region you’re located in
  3. The top three lines of your brave://version page
After providing this info, I may ask for additional information from all of you. I appreciate your patience.
We all are from india. Sir
From India .
Kindly please help
I m from india sir and i m also facing this issue and this is my brave version
Brave - 1.10.99 Chromium: 83.0.4103.116 (Official Build) (32-bit)
Revision 8f0c18b4dca9b6699eb629be0f51810c24fb6428-refs/branch-heads/4103@{#716}
OS Android 9; Redmi Note 8 Build/PKQ1.190616.001
We Both Have same Phone
hey i am having same android 9 and the latest update of the browser
same here in whole friend circle and 1000 of brave users complaining
