I have updated Brave Nightly to the latest build (15.52.51).
Whenever I try to open brave browser, it crashes. Android shows “brave keeps stopping”.
I wanna restore my bookmarks. I didn’t clear storage and cache after updating. And unfortunately I didn’t create a Sync chain and can’t open Brave now in order2do so.
1.Open Brave
2.Open Brave
3.Open Brave -“Brave keeps stopping”.
*Expected result:
Recovery of bookmarks and history.
*Brave Version( check About Brave):
Nightly v15.52.51
Mobile Device details
Name-Pixel 6a
Unrooted Android 12.
Nobody knows? I need your attention!!
Which OS are OS version are you using? (such as iOS 16.4, Android 10, Android 12, etc)
Which version of Brave are you using? (such as Brave 1.50.119, 1.49.1, etc)
Do you have your device synced with any other devices?
Did any other information, such as passwords or history, vanish as well?
@sampson look into this case too. Thanks so much!
Using Android 12.
I didn’t clear storage and cache after updating. And unfortunately I didn’t create a Sync chain (never did a sync) and can’t open Brave now in order2do so.
If you long-press the app icon, are you presented with the option to open a New Tab, or a New Private Tab? If so, do either of those options successfully launch a usable instance of Brave?
Side Note: It goes without saying, but Nightly builds are advertised as being more brittle, and carry a higher risk than other builds. Please only use nightly builds in parallel to a more stable instance of Brave (you can use Brave Sync to keep passwords and more up-to-date between your stable and nightly builds).
I tried to do so. No, it doesn’t work. Are there any other ways to recover bookmarks?
There is no other supported route for bookmark recovery in this scenario. That said, if the crashes only started happening after Nightly updated, it may be that the one of the next Nightly builds resolves whatever issue you’re facing. Am I correct in understanding that there was no crash before the update to 1.52.51, and it began immediately to crash after?
@sampson
Absolutely. My bad that I did it. What do I have do? Wait for another Nightly build and try to update it?
History of my actions:
And yesterday I installed-this build over the old one:
Where are you getting these APKs from, and how are you determining which is the appropriate one to install for your device?
@sampson
Last time I tried to install random version, it was updated successfully (yes, I know, my bad)
@sampson
So what me to do?
Try to install fresh builds from the link below?Thank you
Please let me know what type of device you’re using (e.g. model, manufacturer, Android OS version). That will help us determine the appropriate APK for you to install.
Note that at this point, I cannot guarantee recovery of the bookmarks. To reiterate, Nightly builds are known to be brittle. I do hope we can resolve this issue for you, however, without the loss of any data.
@sampson
Android 12,Pixel 6a
I believe what you want is the Mono ARM64 version. For Nightly v1.52.65, you can find that at https://github.com/brave/brave-browser/releases/download/v1.52.65/BraveMonoarm64.apk.
