Need some help in brave rewards
I don’t get after two days any back ground ads in New tab why not that happened .
Pleas help me.
I believe you’re team toomuch
If you check this site does it show your region has the new tab ads? Also I thought there might be some regions that do not pay out for the new tab page ads. Not sure if this has been fixed or not since. https://sampson.codes/brave/ads/my_region/
Same thing here - reported it in another thread somewhere on here. Its not the first time this has happened though and from experience, it usually fixes itself after a few days.
