Need screen shots for settings menus
**Description of the issue:
I need help with the settings menu. I have somehow made my Brave screen disappear, and per another issue (Black screen but i can still use the brave browser. I just can't see anything ):) I need to go into settings. But this is my only device, so I have no way of navigating to the menu to be able to fix this.
Can someone post screen shots of the menu path so that I can try to do this “blind”?
I have no other device to use Brave on to try to find it myself.
(Side note, this happened when I hit some of the f keys, not realizing my function key had come off. But the fact that this problem can occur from that, but not be undone by clicking f keys is kind of absurd. I tried each one, and none undid the issue, nor did restarting the browser).
  1. Hit some of the f keys (f11, f12, maybe f10) a few times
  2. Realize your browser is now a blank screen and the solution requires you to locate and navigate the settings menu
**Additional Information:**Windows 11
Sorry, here’s the menu path from the other issue: Settings → Advanced → System → Hardware Acceleration Toggle
What keyboard shortcuts can I use in Brave?
https://support.brave.com/hc/en-us/articles/360032272171-What-keyboard-shortcuts-can-I-use-in-Brave
Use graphics acceleration when available
Thank you so much!!!
