I purchased the VPN sub about two months ago. It sucks. Support is mostly non existent. Brave doesn’t even answer their Facebook messages.
@DrexelLake this is the only official place for support on Brave. In order to cancel, you need to go through the method that you used to sign up. If you used Android, then it will be a subscription in Google Play. If you did it via iOS, it will be in their Play Store. And if you did it on any other device, then you would have your subscription management in your account at https://account.brave.com/
So how did you sign up for the VPN subscription and what have you tried to do in order to cancel it?
Hi @DrexelLake, have you submitted a ticket to our form? If so, can you share your ticket number? If not, please submit a ticket here - https://support.brave.com/hc/en-us/requests/new?ticket_form_id=360003078831. Thank you.
