My Recover key doesent work
I tried to recover my BAT´s after I had to reset my PC cause Windows 11 causing some Problems. All good but the recovery phrase that I got isnt working. Can anyone help me?
Hello, Can You Explain in Detail, please what is actually you wanted to recover
I believe your problem might be you cannot restore your BAT using the sync code? This cannot be done with the sync code. Each device has a local wallet that unless it is connected to a custodial wallet such as Uphold or Gemini, all BAT will be lost if you reformat a pc or uninstall and re install brave etc.
That is the worst nightmare that can happen about wallet. I am pretty sure nobody can help with that, because only you know the phrase. Try to restore your wallet on other device. I have the same wallet on my Laptop and my smartphone
