My channels are not verified despite being connected on Brave Rewards
Hi,
I’ve had a verified website and Twitter account a couple of weeks ago, even received some tokens - but today I noticed that verified icon is missing. I’ve reconnected my Uphold, added Reddit channel - nothing changes.
Can you verify what’s wrong?
The above has info.
In short, if your region isn’t listed at the first website I’ve listed, then your connected accounts won’t be considered verified.
It is listed. I’m using Uphold and I’m from Poland.
Could be because of the bug they are having. if you notice, even The brave community acount seems unverified if you try tipping.
Don’t know on what it depends, because on my side it is verified :stuck_out_tongue:
Maybe there is some delay? Can I get answer from some “inside man”?
Sure, lol. Don’t know what’s going on.
@SaltyBanana any assistance you can provide ?
From the screen you posted you’re on mobile, try from desktop cause twitter, reddit and vimeo don’t appear as verified in mobile environment.
Yep, I see the same issue on Brave for MacOS and Brave on iOS (I haven’t verified others).
Only verified creator I’m seeing is *.brave.com, other creators I know were previously verified are showing up as not.
Hi thanks for reporting!
We are aware of this issue and our team is working to address this issue.
Have you tried disconnecting and reconnecting your Uphold account?
None of the things I’ve posted are from mobile. None of my channels appear as verified and for example https://www.hanselman.com/ is - so it’s not some global bug/issue.
If you recommend it - I can do it. Just need the guidance from you - maybe start from reconnecting one of the medium? Or it doesn’t matter and I should try directly reconnect Uphold?
For now, disconnect Uphold from your Creator dashboard and reconnect.
Reconnected. Didn’t touch the channels. For now, nothing changed.
Another thing, that maybe could be informational - Uphold is shown only next to Reddit channel. I don’t know if that’s intentional.
For me (Win10 Version 1.45.127)
*https://twitter.com/cyberethical_me Verified
*https://blog.cyberethical.me NOT Verified
*https://www.reddit.com/user/Asentinn Verified
Since you disconnected/ reconnected Uphold;
*https://twitter.com/cyberethical_me NOT Verified
But perhaps it may take some time to update?
Maybe cache? I’ll try private browsing.
EDIT:
Right, not available in private :stuck_out_tongue:
Thanks for testing that out @riseofshadows
Ok I am seeing the same thing.
Bunch of screens and Brave version.
Uphold Integrations:
Windows 11
Brave is up to date
Version 1.45.127 Chromium: 107.0.5304.110 (Official Build) (64-bit)
I will bring this to the attention of our team for more.
Win10 Version 1.40.109
ALL channels are verified.
@SaltyBanana Is there a GitHub issues thread for this speicifc issue? I’d like to keep an eye on this, if possible.
