My brave browser have more than 5 different profiles and all profiles are linked to same uphold but from the same device and i have bat tokens in all profiles, Now is it possible to get bat tokens to my wallet from all profiles?
i had read only 3 profiles can be linked to uphold and if more than 3 linked brave will disqualify tokens withdraw, is that true?
and why we need to verify wallet in all profiles each time we create? can brave team make easy solution so that every profile is linked as one profile to brave?
@Younglord00,
Each wallet instance takes up a slot on Uphold regardless of where it’s coming from. That said, at this time, there are some unexpected behaviors that have/can occur when using multiple profiles with verified wallets in the way you are describing and it is recommended that you only verify one wallet per profile instance.
i already verified all profiles, what if i link one profile and delete all remaining now?
Doing this you can’t link any device or profile in future with uphold. As you already reached the max devices count.
Max 4 wallet linking limit may I right @Rohit552
Yes, we can link at max of 4. If you lost any device or uninstall browser in any of the devices, you can get the linked count back again. This is all uphold policy actually
