[Jan 18, 2022, 10:52:52.3 AM:ERROR:credentials_promotion.cc(503)] Token list empty
[Jan 18, 2022, 10:52:52.3 AM:ERROR:uphold_wallet.cc(320)] Transferring tokens failed!
yea same here. nobody has responded to my post in the last 48 hours
just try to use gemini . i hope your problem will soon be resolved
i have also gemini but still didn’t get the payout
if you are not having enough bat tokens i suggest you to reinstall the browser or just clear the DATA
i use uphold wallet. should i reinstall?
Noo I can’t do that because i have around 10+ BATs till now and it will be erased if I do this give a proper solution
i suggest you to don’t reinstall otherwise all your data will go
okay then no need for that
do not uninstall or clear data
if you do then you will lose your 1/4 slots for liniking wallet to uphold/gemini
Same here, I send my BATs to a verified Uphold account few days ago and since then I’m not earning any BATs even if I still get sponsored images for example. Please help, thank you !
I have Gemini account connected to Brave, I have same log related to Gemini. I received the Uphold rewards but could not get Gemini Bat rewards. For 3-4 days, I can’t get Gemini rewards.
same problem here i have also gemini wallet
No one has responded to my thread either, browser is up to date, it just stalled out and quit giving ads, and it also still has not paid out for Dec.
I have the same problem bit with a not verofoed wallet, I wanted to connect with gemini but its not possible until now
its working again!!!
Mine is still not working. I haven’t received earned any rewards from ads in 2-3 days.
Edited to add more information:
I think the problem may have started when I verified wallet/linked to Gemini. The process was not smooth and I had problems. My wallet is verified now but I have stopped earning BAT for viewing/clicking ads.
From reading through some previous topics, it appears that when an account is flagged, you stop earning rewards for viewing/clicking ads. I am wondering if the problems I had verifying my wallet flagged my account and that is why I stopped earning rewards.
Does anyone know if there is a way to check if an account has been flagged and if so, how to get the flag removed?
I have the same issue also. I don’t know if I had been flagged but if so why I don’t know. My other 2 devices are still earning BAT. Only one has stuck on 1 BAT
i use uphold wallet. I don’t use vpn but same situation me to have. And don’t fixed 1 week.
Same here, not getting any ads any more and I have not received any rewards from December.
