I have 40 BAT still stuck in the ether
As you can see when wallet is connected I have 60 BAT when the wallet is disconnected I have 40 BAT still stuck. I reported this back in March, sent my screen shots, email, rewards panel, Advertisers_DB, etc… And I’ve heard nothing back and the issue has never been sorted. My thread was closed as if you had fixed the issue which you have not.
And then to rub salt in the wound you give me this much BAT for a month of advert viewing
Bit of an insult that!
I have a similar problem.
70 BAT stuck on my android wallet and not moving to my verified Uphold.
I have been receiving new rewards however.
have you connect your uphold account to more than 4 brave browser??
true…only received a portion of ba to uphold(a portion of bat from exactly one month). Something is wrong somewhere. The creators rewards also haven’t been credited to uphold yet.
Thank you for reporting! Please DM with the following information:
- Copy/paste your Wallet ID (found on
brave://rewards-internals)
- Your OS and Brave version (first three lines in
brave://version)
- A screenshot of your Rewards panel in
Settings --> Brave Rewards.
This will help to speed up the troubleshooting. Thank you in advance!
