Moving rewards between device wallets (no uphold)
Hi. So I have three devices with Brave where I receive rewards but none of them are linked with uphold or any other provider. This bring me different questiones:
  1. Where are those BAT rewards: inside my computer, secured by the password/kew-word combination?
  2. Is there a way I could send the rewards to a single device? I have done, for testing, a “Restore wallet” operation on my mobile on the first install: I set the key combination and password and the wallet opened as if it was on my computer, but still the wallet is empty.
I think the only way is having an uphold account and sending all the BAT from all devices to the same account… am I right?
Thanks in advance
Hi @edugr1982, yes you will need to verify your wallet with either Uphold or Gemini.
