I have been having problems with this Bookmark manager from the beginning I can not change the name in the name fields once there is something in there, I can not move empty folders around if they are not already in the manager lineup (so if I create one in the top menu and drag it to the main lineup to put in another folder as a subfolder
forget it it’s going nowhere!) I have hundreds of bookmarks, possibly over 2000 in many folders and subfolders and it is imperative that I keep them organized, please someone help?
Ed
Hi @vancroft,
What version of Brave are you using?
To move a folder, click on the pen icon at the bottom right, then click on the folder you want to move, there you should be able to change the location.
