Misalignment of switches in dashboard settings
The top most switch in the dashboard settings is misaligned. This is also causing the text on the next line to shift out of place.
  1. Open new tab
  2. Open dashboard settings
Sliders should be aligned and properly sized.
Version 1.3.115 Chromium: 80.0.3987.87
N/A
On all my PCs with different screen sizes the dashboard settings are shown correct.
I’m not sure why the issue is on my machine and not yours as I am still quite new to this browser. If it helps to track down the cause of my issue I was inspecting the element and found that a translate has been applied twice on the dot part of the switch:
There is also a padding-left of 15px applied to the next line, which is causing it to not be aligned with the other options.
@AlexM42 @Johann,
Thanks for reaching out to us. This issue is actually already known and currently being addressed by the team:
