- go to google document, activate mic feature, don’t work, should work
- go to openWebUI, mic don’t work, network error, should work
- Brave 1.80.124 (Build officiel) (64 bits)
Chromium: 138.0.7204.168
3-1. Seem to have the same problem with Chome, but it’s work in Edge. does Chromium have a bug ???
- it use to work but not anymore, I tried everything, global reset to default parameter, clear cache completely, reboot the machine, note that the mic is working in Edge, I desactivate the shield completely, remove all the ext or plugin I have… nothing work…
if I go to https://mictests.com/ with brave and autorise the mic, it’s work
one of my friend that have brave too have the same problem with google doc.
how to desactivate the auto update. ?
