NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
Hi, so I am trying to connect to Dydx and other web3 apps using metamask on brave. I am able to unlock Metamask but the popups that ask to connect with apps no longer appear and when I try to click ‘connect’ with these outside apps nothing happens.
I had tried to install brave wallet too but I deactivated because I prefer to use MetaMask.
Metamask just is, nothing happens, no connection is established and I can’t connect to Dapps
Be able to connect to Dapps using Metamask.
It used to work now it does not.
Mac OS Catalina 10.15 Intel Macbook Mid 2012.
