Briefly describe your issue:
The message appeared in the Brave Rewards panel that rewards had been sent, but they are not appearing in my Uphold account.
What Operating System and Brave version are you using? (Menu --> About Brave)
MacOS, Brave 1.79.119
Who is your verified custodian? (Uphold/Gemini/bitFlyer)
Uphold
Yes
