I just installed the Brave browser today and it unfortunately only runs for about 10-15 seconds before crashing. It does give me enough time to disable hardware sync and seems to be working as a proper browser but only for 10-15 seconds. It then crashes and force quits.
Hey Cade1,
Before I suggest anything, can you answer two things for me:
- What mac are you using, and what is the macOS?
- What chip does your mac have, and did you download the correct version of Brave according to that chip?
I downloaded the intel chip version
Hm, with this being a fresh install of Brave, I would recommend completely wiping your mac of Brave, and then redownloading/reinstalling Brave after you’ve completed that.
