- When I run my Brave browser I’m facing with significant battery usage.
Expected result: Battery draining
Brave Version( check About Brave): v1.47.171
Hello @ario_9271
Thank you for reaching us and I’m sorry to hear you are going through this. Please try In Private mode or Guest Window to see if the behavior persist . If that works, try disabling your extensions to see if this is the cause of the issue.
You can open a Guest Window by going to Main menu → Open Guest window:
Menu → More tools → Extensions.Remove.Be waiting for your response!
