badr
September 3, 2020, 1:42pm
1
Description of the issue: When I open youtube and watch a video the volume is really low.
Open YouTube
Search for a video
Open the video and listen to the sound
Expected result: Really low sound from YouTube video
Brave Version( check About Brave): [Version 1.13.82 Chromium: 85.0.4183.83 (Official Build) (64-bit)
Additional Information: Checked volume mixer and Brave is maxed out, still having the prbolem.
Aa-ron
September 3, 2020, 2:50pm
2
Hi @badr , Welcome to Community!
We have a few threads talking about audio output in youtube, can you check them out and see if they solve your issue:
So I was getting low sound volume on Youtube, Twitch etc and could find nothing to fix.
I went to brave://flags and switched the #try-supported-channel-layouts flag to enabled and volume is now fine.
Hope this helps someone!
The problem is resolved. I tried to take many single steps so I could discover the cause, but I don’t know what finally fixed the problem. I did the following: 1. Uninstalled Brave with program that is supposed to remove all related files. 2. Installed a new copy, with no bookmarks installed and the problem remained in my original profile. 3. Created a new profile and as before found YouTube volumes good in the new profile 4. I opened my original and the new profile and opened to “settings”…
Thank you @Mattches for responding . I tried your suggestion and it did not work. I spent a little more time on this and I really don’t know whats wrong. I did however uninstall NVIDIA audio drivers & disable/enable the windows audio drivers. Good news is that the problem is not happening in Edge and Brave at this exact moment. So I’m cautiously optimistic that the problem is fixed.
badr
September 3, 2020, 2:54pm
3
Thank you but the first thread about turning #try-supported-channel-layouts flag on, but I can’t find the flag itself.
Aa-ron
September 3, 2020, 3:01pm
4
Oh sorry, then ignore that one, it looks like it may be a depreciated flag.
badr
September 4, 2020, 8:04pm
5
Tried every solution, none worked,
@badr ,
Can you please try creating a new browser profile (Menu --> Create profile) and see if Youtube’s volume still sounds lower than it should when using the new profile?
system
Closed
October 8, 2020, 4:19pm
8
