Log out problem - SOLVED
Every time i quit Brave and run it again, browser is logged out of all the sites. I have to log in to all the sites every time. Can someone help me with this problem?
Brave Version( 1.78.102 Chromium: 136.0.7103.113 (Official Build) (64-bit)):
@Karas
Take a look at:
Thanks for the reply. Looks like the those are fixes for Google services only. While i experience loging out of all sites. If i apply these fixes, will it stop my browser from logging out of non Google sites too?
@Karas
I suggest that you use the Brave Community search feature, looking for related issues.
I checked other related topics, i read suggested solutions. Looks like my problem was “delete browser data on exit” was active, though i don’t remember activating that at all. Anyway, my problem is solved. Thank you very much.
