LinkedIn keeps reloading, tried clearing linkedin cookie and site data
Same issue as this link here:
Tried the tips to solve:
  1. working fine in incognito mode
  2. deleted the cookies related to linkedin by going onto this path as best as i could, ** Navigate to Settings --> Advanced --> Privacy/Security --> Content Settings --> See all cookies and site data **
    , but then as soon as i open a new tab, go to linked in, and then signin again starts happening automatically using Sign in to LinkedIn with Google
Brave 1.60.125 Chromium: 119.0.6045.199 (Official Build) (64-bit)
Revision 9c1f9e267d7ef50aefbe434e616e05290536926b
OS Windows 10 Version 22H2 (Build 19045.3693)
JavaScript V8 11.9.169.7
User Agent Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36
if possible give the exact location of deleting linkedin cookies and site data, as the version has changes and thus this navigation has changed too.
  1. Navigate to Settings --> Advanced --> Privacy/Security --> Content Settings --> See all cookies and site data
Console data
wwwdotlinkedindotcom/:1 Unchecked runtime.lastError: The message port closed before a response was received.
inject.js:1 [Deprecation] Listener added for a synchronous ‘DOMNodeInserted’ DOM Mutation Event. This event type is deprecated (httpscolon//w3c.github.io/uievents/#legacy-event-types) and work is underway to remove it from this browser. Usage of this event listener will cause performance issues today, and represents a risk of future incompatibility. Consider using MutationObserver instead.
s @ inject.js:1
setInterval (async)
(anonymous) @ inject.js:1
Show 2 more frames
Show less
7q7t5r4unney3j047t8abxaiv:1 Element with id: isLinkedInAppWebView not found
As @ 7q7t5r4unney3j047t8abxaiv:1
Ws @ 7q7t5r4unney3j047t8abxaiv:1
(anonymous) @ 7q7t5r4unney3j047t8abxaiv:1
setTimeout (async)
load (async)
L @ 7q7t5r4unney3j047t8abxaiv:1
7q7t5r4unney3j047t8abxaiv:1 Element with id: isTermsAndConditionsSkipEnabledOneTap not found
setTimeout (async)
load (async)
7q7t5r4unney3j047t8abxaiv:1 Element with id: isTermsAndConditionsSkipEnabledAuthButton not found
setTimeout (async)
load (async)
7q7t5r4unney3j047t8abxaiv:1 Element with id: googleAuthLibraryPath not found
Promise.then (async)
_initGoogleAuth @ 7q7t5r4unney3j047t8abxaiv:1
setTimeout (async)
load (async)
lnkd.demdexdotnet/dest5dothtml?d_nsid=0#https%3A%2F%2Fwwwdotlinkedindotcom:1 Unchecked runtime.lastError: The message port closed before a response was received.
utag.js?cb=1701597300000:8 visitor.publishDestinations() result: Attempted to attach and load the destination publishing iframe through this API call. Result: The destination publishing iframe was attached and loaded successfully.
button:1 Unchecked runtime.lastError: The message port closed before a response was received.
select:1 Unchecked runtime.lastError: The message port closed before a response was received.
s @ inject.js:1
setInterval (async)
Show 2 more frames
Show less
s @ inject.js:1
setInterval (async)
Show 2 more frames
Show less
s @ inject.js:1
setInterval (async)
Show 2 more frames
Show less
@abhishek1141781 this gives you the answer on your issue. Think of it this way. The only difference between private/incognito and normal windows are:
  1. It starts the session with no active cookies
  2. Extensions are disabled by default (as long as you haven’t changed that setting)
  3. It clears history and cookies from your session when you exit
Generally, if it works in private window but not normal, it means it’s one of your extensions causing issues. This is even further affirmed by you saying you’ve cleared cookies and the issue still occurs.
So I’d remove your extensions and give it another shot. Or, if you’re worried about removing them to test, then create a new profile that you can use for testing purposes. This won’t erase your existing profile but just will create a second one for troubleshooting purposes.
If you’re not sure how, go to Hamburger Menu image → More Tools → Add new profile.
New profile will be default Brave settings overall (it maintains custom content filters and any changes you made to brave://flags) and no extensions. If new profile works perfectly fine, then it should be an easy confirmation for you that one of your extensions is indeed the culprit.
Then you either add one extension at a time to your new profile until it breaks again or you’ll remove from original profile to see if it starts working again. Either way, just will be trial and error until the culprit is found.
