Less BAT received
For June, I had to receive 2.22 BAT, but I received only 0.915 BAT in Uphold. Why? Is there any known issue? Can I claim the remaining 1.3 BAT?
Briefly describe your issue:
What Operating System and Brave version are you using? (Menu --> About Brave)
Who is your verified custodian? (Uphold/Gemini/bitFlyer)
Payouts are still processing.
Please wait till it’s completed. If you still don’t receive, ping here.
Thanks for your answer.
Can you estimate how long will it take the completion of the payouts?
Umm they are complete. Did you receive the payment?
As I wrote before, in the Brave browser the amount of BAT had to be 2.222. I received only 0.915.
Checked few seconds ago.
Okay.
Please raise a ticket at
Once raised, please share ticket id you receive in the email you submitted.
Also, support might take upto 3 to 4 weeks to get back to you. So be patient. They are handling a lot of tickets lately.
Done.
My ticket number is 207097.
Yes yes, always the same answer… Post a ticket, and than what? I’ve done this and I received no answer! So many topics on this support forum about similar problems…
Zrzut ekranu 2023-07-12 101254
When did you raise it ?
@RobaQ87 @Landre Please check out
I open the ticket and this was the answer:
“There was an issue with NTP ads last month, which resulted in an incorrect payout status for Rewards. Please note, there is no issue with payment and the correct amount has been paid out based on ads viewed.
We apologize for the confusion in the Rewards payout messaging.”
Ok, so there was an issue in the calculation of the amount of BATS to be payed out.
Is the issue fixed? This month the amount will be correct?
Yes, support assured me it will be correct this month.
They wrote message to me that everything is correct, the first amount of BAT(7,000) was an error, and the correct amount is that what i got… Like I said erlier, it’s smels like scam! And i know I’ll got this post flagged cause is telling the truth, but they are scummers and they alvays will say that the error is on their favour. My advice is to change browser and don’t let them making money on you.
