LastPass extension will NOT download
I am not able to install LastPass extension into Brave
I go to the extensions page and try to download. The popup for checking with the accept button shows then I get the error as shown. Look at the bottom of the image. I have tried multiple times. I have made Brave the default. Turned off shields for the chrome webstore and disabled my virus program.
Nothing works.
I would like LastPass to work
** Version 1.25.72 Chromium: 91.0.4472.101 (Official Build) (64-bit)**
Also brave won’t update. See this image
Snap2022-07-23, 09_10_59
Do you have any extensions installed/enabled? If so, does it still happen with them all disabled?
Also, which version of Windows is this, and is it up to date?
I disabled the one extension I had and it still did the same thing. I am using Windows 7 Home Premium
I just tried turning off safe browsing and same thing
OK. I got it. I just installed the latest Brave from the downloads page. Once that was done I was able to install the extension.
Thanks for the reply
