Keyboard shortcut for Reader View?
I use Reader View a lot. I notice it has moved from the hamburger menu to the view menu, which I’d say is an improvement. It would be wonderful if I could access Reader View with a keyboard shortcut!
I completely agree! it would be much more convenient
I rarely use “Reader View” so your comment alerted me to a change to Brave I’d not noticed; thanks.
Where is Brave’s “view menu” to which you refer?
In this comment @Aa-ron provides guidance to re-enable reader mode; no joy, at least not for me.
I’m aware: not every web page can be viewed using “reader mode”. As a test, I loaded a page in Firefox that displays as desired when I toggle “Reader View”. (An icon in Firefox’s unibox or F9 in Firefox conveniently do this.) No success with that page (or any other) in Brave.
In my experience, Brave reader view has improved dramatically. I used to have all sorts of similar grief with it.
temp-brave
Aha! I see you’re using the Mac version. Brave’s Windows version (which I’m using) doesn’t offer even an optional “Menu” Bar (though it’s been requested), hence, nothing similar. But I agree: when Brave offered a Reader Mode, I found it helpful.
@BarryEd,
Sounds like a good feature request!
Also Brave does have a speed reader that is under a flag. Please see:
SpeedReader will be able to recognise an article and enable itself. If anyone here would be willing to test it out and give feedback we would really appreciate it.
I enabled Speedreader, and as far as I can tell it does absolutely nothing. I still have to go to View>Toggle Reader Mode, and there is no perceptible difference in how fast the reader page loads.
Yikes! I’ve been using Macintosh for almost 35 years, and never realized how simple it is to create an application-specific keyboard shortcut! Done…
Also if you can enable dark mode in reader view will be good. I use it more in firefox which maintains the focus on text and Pics alone instead of white spaces. Also, to print the reader view page in dark mode in PDF format is also a better option
@Aa-ron-
I just enabled and tried Speedreader on bbc.com which is one of the sites on the Speedreader whitelist. Quick summary: technically, it works — no glitches — but I find the resulting page is actually more difficult to read than without Speedreader. Which may explain why some time elapsed between when Brave deprecated its reader mode when and I first noticed its absence: I rarely used the option, though the old reader mode was visually much more helpful than Speedreader.
Also worth adding: as I noted in another comment in this thread, I tried re-enabling Brave’s reader mode:
brave://flags
search for and enable enable-reader-mode
re-start Brave
Actually, under enable reader mode, in addition to Default and Disabled, I’m offered two other options: Enabled and Enabled available in settings. Selecting Enabled and re-starting results in no apparent changes; selecting Enabled available in settings and restarting reveals a new line in Settings | Appearance: Reader mode for web pages Offer to show articles in reader mode, when supported. That’s switched ON, but results in no change to what’s displayed.
Repeating: when it was available I used Brave’s reader mode rarely. For me, this is low-priority.
tried this flags
brave://flags
re-start Brave
not working in latest version of Brave V1.21.74 (Mar 6, 2021)
Thanks for following up on this topic. Frankly, I’d forgotten about it; forgotten, because Brave, doing what it does, eliminates most of the reasons I’d previously used a reader mode — getting rid of distracting clutter.
With your reminder in mind, I checked brave://flags — Under Enable Reader Mode, the “Enabled available in settings” option is selected, and in Settings “Reader mode for web pages Offer to show articles in reader mode, when supported” is on. However, no web pages I visit — including - specifically - websites on the Sitelist included in @Aa-ron’s comment earlier in this thread result in a “SpeedReader” icon appearing.
At least for me, “reader mode” or as Brave characterizes it “SpeedReader” doesn’t seem to work, but what Brave already does makes this irrelevant.
Same here (02.2024).
I would very much like to encourage more attention to this request. Reader View does not always activate automatically. Nonetheless, often I like to switch it off, or as said when it does not activate automatically, switch it on. Assigning a quick kb shortcut that I can bind to a button on my mouse allows for this to be done much more easily. Even moreso, even without a mouse shortcut button, it would be great to just quickly tap F9 (as is the case for most other browsers*) to toggle the mode on or off.
Please, and thanks.
asterisk = edit
I am looking for this shortcut, too. It would make reading articles so much more convenient.
Also check: https://github.com/brave/brave-browser/issues/8372
As Valynor mentioned, you can short your support for this feature by upvoting the issue on GitHub: https://github.com/brave/brave-browser/issues/8372
