JumpToken does not appear
Is the issue occurring on a specific network?
No
What operating system are you using?
Android 12 (Xiaomi Mi 10T Lite)
Brave 1.51.110, Chromium 113.0.5672.77
I’ve already tried two times to withdraw JMPT to Brave Wallet, but it doesn’t add them to it, I added JMPT to Ether and BSC but in both of them still have 0 JMPT
The transaction hash you shared was done on the Celo network. It’s not available in Brave Wallet by default, but you can add it by going to brave://settings/wallet/networks, clicking on Add and searching for Celo. Here’s a screenshot:
Once the Celo network is added, you can add JMPT token (https://celoscan.io/token/0x1d18d0386f51ab03e7e84e71bda1681eba865f1f) as a custom asset under the Celo network. Unless I’m missing something, adding JMPT to Ether and BSC will not help.
Let me know if this works for you.
Im struggling a bit because I don’t find the search option. And when I type brave://settings/wallet/networks it changes brave to chrome. I could add it manually, im waiting to earn enough passive incomes to withdraw some, i’ll mark your answer if it works, thanks! (Btw, everytime I open Jumptask it prompts to change to BNB)
I still have 0.0000 JMPT, and I withdrawn 0.007
@onyb
Definitely looks like something is wrong with the configuration. Can you please answer the following:
  1. Is your account address 0xA9868aFDc3f314E8BA7732066E019CDB2e87E440?
  2. How did you add JMPT token? Can you upload a screenshot of Edit Visible Assets > Add custom asset with the details filled in? You can delete your existing JMPT token first.
That’s the JumpTask dapp is instructing Brave Wallet to do so, so I’d say it is expected behaviour.
I add it from Jumptask, it has an option where you just click “Add” and prompts to add JMPT
