Brave is not supported by jiocinema.com, a streaming service in india. Is there any solution to this
I don’t know if it depends on jiocinema or on brave, but this has really been an inconvenience.
I think jio cinema has blocked Brave
Yes, this issue needs to be fixed.
Can you test the following in brave://adblock @MichaelStan
jiocinema.com##+js(brave-fix)
Add to custom filters, save and then reload jio.
it works. Can you tell me little bit more about this. I am curious.
Yep same problem, although the custom filter provided by @fanboynz did fix the issue. But please fix it by a proper update.
I’ll issue a fix later tonight to cover using the site.
Has the fix been implemented, @fanboynz? It still doesn’t seem to be working without the custom filter you provided.
