Been noticing the last few days that on the old MUON build the charts are compiling but on the updated Chromium build (with and without shields) that they will no longer appear. Not sure what is exactly going on here.
What else have you tried?
Shields up/Down?
Do you have Block Scripts enabled?
All combination of Shields up/down and Scripts on/off
Try this:
- Set you’re Shields to default settings on CMC
- Click the lock icon on the left side of the address bar
Site Settings --> Reset permissions
Reload the page and try again.
Did you apply the CSS filter to the site at some point? Maybe even on accident?
Right click anywhere on the page and select Brave --> Clear CSS rules for this site
Did that, oddly still no luck.
Yeah this is very strange. The site displays as intended for me on all available Brave builds. Does it work with Shields down?
Can you share a screenshot of your Shields panel (on the site) as well as the permissions that appear when you click the lock icon?
Yes!
Good stuff! Thought I was going to have to do some real digging to figure that out. Glad it was an easy “fix”.
UP
