Issue loading Crypto Wallets
I’m not sure if anyone has had this issue, please forward me to the original-if there is one at all.
When creating a crypto wallet in the windows desktop browser, after creating a password and opening it up results in a Type Error.
  1. Click on Crypto Wallets in Settings.
  2. Select the Connect button for Trezor
  3. Download backup phrase and click next/continue
  4. Error shows
I’m assuming I would be able to see a different screen showing the wallet interface.
Brave Version:
1.13.82
I did not have my Trezor connected, which would be an obvious issue. Trezor Bridge was not running either. Also I did have some crypto wallet extensions. The extensions I had at the time of installing the wallet were: Lastpass, Honey, BetterTTV, FrankerFaceZ, The FFZ Add-On Pack, TronLink, and MetaMask.
I don’t have any assets in the wallet, so I can just make a new one. Is there any way to basically restart and make a new one?
Here is some additional information. Here is the error message:
TypeError: Cannot read property ‘balance’ of undefined
at chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui.js:1:2576729
at chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1186943
at chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1187437
at y (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui.js:1:2576682)
at ha (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1059446)
at ju (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1104711)
at kl (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1090256)
at Rl (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1090181)
at xl (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1087521)
at ml (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1084265)
at is (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1112272)
at chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1113505
at Sl (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1087872)
at cs (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1113490)
at render (chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui-libs.js:1:1115419)
at chrome-extension://odbfpeeihdkbihmopkbjmoonfanlbfcl/ui.js:1:3584895
We still don’t have support for new Trezor bridge probably thats the issue
That could be be possible. My issue is that i don’t even get to that screen. I go straight to the error screen. I’ll look more into that github though.
I’ll close the thread in favour of the github issue. Please open a new one if you run into anything else. I’ll add a +1 on your behalf on the issue as well
