Issue casting to TV
Description of the issue: Casting to my Sony Bravia google TV shows black screen with audio. The chrome cast is built into the TV no way to manually reset it. Casting from the Chrome browser works.
  1. Cast from web browser tab to TV
Expected result: Video and audio show up on the TV
Brave Version: Brave 1.91.175 (Official Build) (64-bit)
Chromium: 149.0.7827.155
It was working two weeks ago, I believe the new update may have caused an issue.
Can you confirm that you have the Media router option enabled in Settings > Extensions?
if you referencing this then yes
No and that actually might be what’s causing the issue. Can you please set that back to Default value (restart the browser when prompted) then, in Brave, go to Menu > Settings> Extensions and ensure the Media router option is toggled “on”:
Yup that one is checked and I reset all flags. edit: this unfortunately did not fix the issue
Hmmm interesting. I also have a Sony Bravia and casting seems to be working okay for me. Do you have any extensions installed at this time? Also what type content specifically are you trying to cast?
TV Model XR-50X90J
trying to watch fifa world cup. No extensions downloaded may have to do a re-install to see if that is the fix required.
edit: uninstall and redownload did not work unfortunately
@AnnShank can you tell me what site you’re trying to cast from? Also does this happen for every site you try to cast to your tv from?
yup every site i tried so far allows audio but no video
I had similar issue. I turned off hardware acceleration and it worked. Though the tv brand was different, but it runs google tv
just did this and it now works. Thank you!!
@saiyance thanks for the assist
