Is there any fix for Uphold and gemini showing "not available in your region" in India?
Issue with uphold and gemini showing not available in your region
This is because India can’t connect to either right now.
1 year over
No more updates for Indian users …
If you had Gemini connected to the same rewards profile earlier then there’s a chance you might to be able to re connect to Gemini.
If you were never connected to Gemini earlier, then as Saoiray already mentioned, there’s nothing that can be done until India is brought back as a supported region.
