By mistake I uninstalled brave from my smartphone. Is there a way to recover bookmarks?
Did you have an active sync chain with any other devices of yours?
If yes, then you enter the sync chain code which is of 25 random words on your device and you’ll be able to recover the bookmarks and other shared data.
If you had not opted in to sync then I’m not sure about how that works
