I’m trying to install an extension that helps me make the best of my time. That said, if I can easily remove it I doubt that it’ll be very effective. So I’m wondering if there is a way to force an extension to remain installed.
Related topics
| How can I prevent extensions from being disabled/uninstalled? | 1 | 779 | February 5, 2024 | |
| How to prevent Brave Extensions from being disabled or removed | 2 | 2526 | August 11, 2022 | |
| block actions of modify/deactivate/unnistall the extensions by password | 0 | 615 | July 11, 2023 | |
| How can I prevent my extensions from being deactivated again if I suddenly feel like watching porn? | 4 | 70 | March 25, 2026 | |
| Automatic disabling of extensions | 2 | 721 | November 2, 2021 | |
Can you remove extension feature from Brave (mac os Montrey)
1 | 40 | October 27, 2024 | |
| Once an extension is installed the link to the Chrome Extension Store disappears | 2 | 633 | January 19, 2019 | |
| Manually added extensions disappear upon Browser update | 1 | 475 | November 30, 2023 |
