Is there a way to increase page scroll speed?
I find the page scroll speed when using the mouse scroll way too slow. I know that in Firefox there’s a way to increase it, changing some config in the browser. I was wondering if there’s something similar for Brave.
Glad if someone could help. :slight_smile:
@ViniciusBortoletto,
There is no “official” setting available in the browser that can do this. I know that you can set these types of preferences on your PC [System settings] – there may also be a flag you can flip in brave://flags that will change scroll behavior, but off the top of my head I don’t know if that would serve your purposes.
Apparently disabling “smooth scroll” increased the scroll a bit, but still not enough for me. Fortunately I found an extension called “Chromium Wheel Smooth Scroll” and it fixed my problem.
Thanks for the help!
