Hello. Is there a way to disable ad blockers without disabling protection from trackers? Currently the only option I see is to block both tracker & ads.
It would be great if they can be disabled separately.
No, ads and trackers usually are together and the same thing. Regardless, there’s no way to tell them apart in general
