Is it possible to create URL shortcuts including replacement strings?
While I was a Firefox user, I created numerous bookmark shortcuts with built-in replacement strings. All I had to do is type the bookmark shortcut followed by a string, which was then automatically replaced when the bookmark was parsed. For example, here’s one I created for eBay:
Keyword: ebay
URL: https://www.ebay.com/sch/i.html?LH_PrefLoc=1&_sop=15&_nkw=%s
Firefox replaces the “%s” in the URL with whatever text I enter after the keyword. To use it, all I had to do is type the following into the address bar:
ebay autocad
Upon pressing enter, the URL was automatically parsed as:
“https://www.ebay.com/sch/i.html?_sop=15&rt=nc&LH_PrefLoc=1&_nkw=autocad”
Is it possible to do something similar in Brave? Brave is a great browser, but I truly miss this functionality. It was a fast a simple way to get exactly where I wanted to go.
Yes!
It’s a little different – instead of being stored as bookmarks, you store them as custom search engines. But the functionality is the same.
