Hi, I use my iPad every day like a computer, but 2 features are missing from Brave for my use…
- The groups tabs (like if you are on a computer with colors and organisation, just drag and drop your tab to the group or click right or long press on the tag to create a new group)
- Improve the custom search engine. At the moment we have the custom search engine (for example we can add youtube.com/search?%s), actually the icon appear at the bottom of your screen when you make your search, it’s not very UX friendly (because you need a one more click). So i suggest to also add, like on computer, after setting our custom search engine we can use the TAB KEY. For example : youtubeTABKEYmysearchENTER, only with my keyboard I can do a fast search like on a computer.
Thank you for your consideration,
See you soon, ![]()
